RLS7201
Aug 31, 2020Explorer II
Rocket9k wrote:
Thanks everyone for all the info. I still need to check and probably change the transmission fluid. Last I checked it will still clear and smelled correct but i'm sure it's due for a change. RLS7201, your name has come up a bunch of times in the forum posts i've skimmed on this topic. I came across a post you did about making your fan clutch adjustable, but it's older and the pictures are gone. I'd like to see that if you still have the pictures? I'm thinking I can tweak mine to get it where I want it.
Here is the pic. Cut slots in the two aluminum posts. Epoxy a piece of 1 1/2" EMT in the slots cut slots for the spring.
You won't like it. No mater how you adjust it, it will come on too soon or too late. Did you check your radiator to see how many fins per inch it has? As seen in the pic, adjust spring end CC to engage sooner.
Richard
