Rocket9k
Aug 31, 2020Explorer
Richard, it looks like you were moving the spring around considerably on that thing. Is that a Hayden 2799? From what I understand, 1/8" gives you approximately 10 degrees difference in engagement temperature. Did you find you had it move it more to get a change? It's going to be 84 degrees here tomorrow, so I may go wring its neck a bit and see how it does.
To answer your radiator question, I have an all aluminum replacement from superior cooling, as well as a complete banks system. It seems to do the job very well. The temp gauge stays between the O and M on the ford NORMAL gauge (190-210 according to my IR gun) which is well within acceptable temperature range for the trusty 460. If I am out of overdrive in 3rd gear going down the highway at 65-70 the temp will goto A, WITH the dash A/C on. I am sure if i'm climbing with a load on it will go beyond that, which is why I want to be sure my fan is working properly. Where exactly did/does your factory fan clutch kick on if I may ask, on your \__NORMAL___/ gauge?
I may have no problem whatsoever, but I would like to be 100% confident that I do not before I venture out on long runs.
