Ford Gas Chassis for 38 footers ?
Devocamper
Looking again at a switch from fifth wheel to motor home again, looked around last year and was very disappointed with quality. My current question is for those that have larger gas motor homes on the ford chassis 26K and how they handle the load? It seems from my test drives of coaches in the 36 foot range were taxing the chassis. I have found two floor plans that we like but they are 38 footers, the Winnebago adventurer 38 Q and the Itasca same model as well as the newmar canyon star 3914 . Just looking for real world advise on how these coaches handle long grades towing a small suv or should I be looking at a diesel in this size?
Thanks
Mike
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
66 REPLIES 66
tropical36
Thanks
Mike
You'll have the power, no problem, unless you're wanting to run a road race to the top of the longest and steepest grades. Transmission will be sufficient for the load, as well.
Diesels are another animal altogether and we recently purchased our first one ever. Probably not ever going back, now that we did so, but one must be prepared to support these beasts, as well and if it was just for the purchase price, everyone should have one, whether they thought they needed it or not.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
usersmanual
pslocum wrote:
We have a 35' gasser on a ford chassis and it handles fine up hill or down, it's a 22000lb chassis the 38' foot Winnebago Adventurer is on the 26000 lb chassis I'm very sure that it would be fine it's a very nice coach and there are some great prices out on the net.
I've driven truck all my life and I'm not hung up on a Diesel engine. If you can afford one and want one fine but they all have there good points and not so good points. As far as handling complaints its IMHO usually from people not used to sitting so high in a fully loaded vehicle and they are just plane scared thus they hang on to tight and get white nuckles and complain about handling. It's not a car and will not handle like one. The advantage many diesel coaches have is air ride that can compensate for weight shift on corners and an engine brake that is nice,... but gives many a false sense of security on grades. You still need to be in the correct gear because engine brakes can and do fail, yes if your in the correct gear you will not need to use your service brakes as much ........but brakes are relatively cheap and for the $ you can purchase a lot of gas and brakes pads.
No doubt its a nice decent MH and they work fine.But comparing your MH to a allegro bus or a monaco dynasty or a winnibego tour or a newmar dutchstar is plain silly on your part,
they outshine you on quality of build, Chassis, handling,brakes,power,
looks,ride,options available .The down sides are there too expensive these days. I can safely go down a hill at 55-60 MPH using my engine brake.You cant in a V10 gasser
usersmanual
carringb wrote:
Bruce Brown wrote:
It's not that a gasser can't do it, it's just that a diesel does it sooooo much easier, both uphill and down.
But why does it always seem to be diesel pushers holding up traffic on 2-lane mountain passes? It's been years since I've been held up by a modern gas coach. Sure, there's some older, slower motorhomes out there, but those drivers have the courtesy to use pull-outs and let traffic by. Do diesel pusher owners feel like they are exempt from using pull-outs to let traffic pass? Or are they unaware of the mile-long backup stuck behind them? I drive over the cascades almost weekly, and this has become weekly theme.
BS older underpowered MH hold u up for sure but I will guarantee you a NEW 37 ft ford V10 loaded MH will be the major hold up on mountain roads not a 425HP ISL Diesel pusher and if its a long enough and steep grade all MH will hold up a passenger car or truck
y
pslocum
2017 Winnebago Vista LX 35F
Lund 1675 50 hp Honda
FMCA F462274
carringb
2014 ORV really big trailer
2015 Ford Focus ST
Bruce_Brown
Moderator
Moderator
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
wildviking
Goldencrazy wrote:
usersmanual wrote:
Goldencrazy wrote:
Always amazed at how many responses of people who don't own one. I have a 2016 38Q. It is fantastic and plenty of power. I had smaller gas before the six speed and they were fine but this is fantastic. Up and over Monteagle without trouble. Haven't been west yet.
BINGO Quote: Haven't been west yet.
I have been west in a 2012 30t and 2015 35g. Both were fine. The gas is ok. Diesel will be better if you find the layout and the price. I like my layout and the price as it works for me in all conditions so don't be afraid of gas. If you spend most of your time in mountains diesel would be a better choice if possible. Good luck.
I have to agree but with one addition if you only go uphill in the mountains then it really is important but I found with our last MH that was a DP most times we could go no faster down the mountain then the most underpowered gas coach. I still am wondering where this place out west is where only diesels can tread
Goldencrazy
usersmanual
Buy what you like and what suits your needs and pocket book.Thats what I did.
carringb
My V10 sounds great at 5,000 RPM!
2015 Ford Focus ST
427435
usersmanual wrote:
427435 wrote:
usersmanual wrote:
OK back to reality!
anyone that thinks their 3 slide 38 foot ford 460 lb torque class A MH
loaded and towing is in any way comparable to a mid to upper end 40Ft 4 slide 450HP 1250 lb torque Diesel pusher are living in a fantasy world
IT will and can out power you on hills hands down, Out brake you coming down hands down, out GVW you hands down, never mind a much quiter ride, never mind far far superior suspension's, never mind better and more options, never mind more storage, never mind a superior build and quality all around
but you beat the hell out of us on Price
But we see the same scenery!!!! ๐Ÿ™‚
As for a quieter ride, the one DP I drove (a Monaco of about the same vintage as my gasser) wasn't any quieter. Of course the $150 worth of Dynamat helps a bunch.
We agree on the scenery for sure. Dynamat or not your V10 at 5000 rpm pulling mamouth mountain ca will out scream my ISL at 2100 RPM all day long my friend mark my words on that
Typical proud DP owner trying to justify the $$$$ he's spent. I've never needed to run at 5000 rpm. And for every hour of climbing a long grade, I've spent hours and hours at 3500 rpm or less. At those rpms, the major noise is wind-------------which was the same in the DP I drove.
My MH, likes yours, is a depreciating asset. What I didn't spend to buy a DP, 10 years, ago is now worth more than what I paid for my MH in the first place. :C
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Kayteg1
We have lot of comparison similar to diesel v/s gasser.
Just like buying expensive solars v/s $80 generator.
Or LED lights that not only will save you tons on energy, but will last for the rest of your life.
Make your choices wisely.
hanko
usersmanual wrote:
OK back to reality!
You know, Usually guys that talk like this are lacking in some other dept.
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
usersmanual
irishtom29 wrote:
It takes all day to climb that mountain?
beats the hell outta me. never climbed it? drove by it many times:B
