samuraitowd
Dec 19, 2018Explorer
Ford gas tank access from coach?
Need to access the fuel pump area. Has anybody measured and cut a hole through the floor under the bed to access it that way? The gen isn’t getting fuel and everything looks good back to the tank. I put a primer bulb on the line and it just sucks air so want to check the hose/tank connection. We had the tank dropped a couple years ago to replace the fuel pump and don’t want to spend another $1200 on this. Thanks for your help!
