- JAXFLExplorerEternabond tape I have used on the patio seams....that is why I sprayed Flex-Seal as after a couple of years it leaked again. So far it has been 2 years and no leaks.
- mlts22ExplorerI looked at reviews on earlier posts, and from what was mentioned, Flex-Seal doesn't seem to do well. A Rustoleum product was mentioned, but not sure which one that is.
I wonder how usable Eternabond is, but since I've only had a limited experience with it, my knowledge on how it does for the long haul will be secondhand. - JAXFLExplorerSpray it yourself. That commercial you see on TV about Flex-Seal that is now in colors and CLEAR. Spray it with the clear and no one will ever know. Works great on my patio roof.
- mlts22ExplorerWhile looking at the Forest River roof, I can't help thinking about going at the top with Eternabond so I have the tape over the screw holes, and one side on the fiberglass, the other side just over the curve of the roof. Then hit the edges of the tape with EternaCaulk mainly for asthetic reasons, as well as another water barrier.
Of course, the ideal would be to take it to a place like Rhino Linings or Dave's Permanent Coatings, and have their epoxy elastomer stuff sprayed over the seams, fiberglass roof, and around the vents, skylights, and other items. This way, there are no seams or gaps for water to intrude into. - pnicholsExplorer II
Markiemark32 wrote:
In general less issues with hard fiberglass roofs.
Even then, the more preferrable one piece fiberglass roof structure is one that also has it's edges molded so that they curl over the sides 3-4 inches all the way along each side.
It's not good to have a seam all along the edge of the roof - whereby if you don't constantly keep an eye on it over the years - water can get in and leak vertically right down into the interior of the walls. Of course, the roof should have a nice crown to it, too. - Markiemark32Explorer
j-d wrote:
We just put ours (signature) into the shop for leak repairs. Parked next to it was a Forester. I don't know what the FR was in for, but the shop owner said words like "Look at that Forester. They build a good roof."
Forest River has the fiberglass roof's on their C's versus rubber roofs,as well as Winnebago, Itasca(to name mass produced ones), smaller companies Nexus, Born Free, Pleasure Way (smaller companies).
Not naming them all ~~~
** NOW there are still seals that need to be maintenanced and kept after to avoid leaks **
Markiemark:C - JopopsExplorer
Markiemark32 wrote:
Jopopsy wrote:
The structure might be the same, but I believe the overall content of the Sunseekers is less than the regular Forester.
Itasca / Winnebago is more along the lines of what you are thinking. They are exactly the same save color scheme and badging.
From Forest river rep on the Forest River forum.
"same coach, no difference other than features. they are built on the same chassis down the same line."
A few of the features Forester:
• Skirt Paint (Standard)
• Raised Wood Refer Panel (Standard)
• Vinyl soft-touch ceiling
• Recessed glass LED light fixtures
• Fiberglass running boards
• Memory Foam Mattress (Standard)
• LED Floor Lighting
• Hidden Hinges
• Cedar Lined Closets
• Outside Security Light
• Solid Surface Galley
• Fantastic Fan w/ Rain & Temp Sensor
• Upgraded Sprayer faucet
Markiemark:C
That's basically what I said. A Forester is basically a Sunseeker with a Premier package. - j-dExplorer IIWe just put ours (signature) into the shop for leak repairs. Parked next to it was a Forester. I don't know what the FR was in for, but the shop owner said words like "Look at that Forester. They build a good roof."
- JAXFLExplorerI have a Sunseeker and to tell the truth I would not want to pay the extra price to the few things the Forester has. We have had a lot of fun with ours and very few problems.
• Hidden Hinges
Markiemark:C
About Motorhome Group
38,705 PostsLatest Activity: Jan 24, 2025
