Forty Foot Gasser
houtrz
We are looking at buying a Class-A in a few months and like the Forest River Georgetown 36k7. Its a 40'1" long gas coach. Some
are built on the old chassis with a V-10 and some are on the new chassis with a V-8.
That seems like a long coach for a gas model. Anyone have experience with a forty foot gasser? Since they have been built on both the old and new chassis, should I buy one over the other?
12 REPLIES 12
blazenpm
We own a 37ft. Forrester Georgetown XL. Our powerplant is a very healthy V10. V10's have gotten a bad rap because of the sparkplugs blowing out of the head. If the plugs are torqued to the correct specs. then there should not be a problem. So far, knock on wood, no problems on the road towing our Honda CRV. I have not weighed our rig when it is loaded but I believe we are within the load limits. I am not familiar with the "new" V8 that apparently is being installed in the newer Forrester motorhomes. I did find out on this website that the V-10 gets its best performance when pulling a hill at 4500 RPM.
Horsedoc
We have a '16 Newmar Canyon Star 3911. It does fine but we liked our previous DP better as far as ride and noise goes. We had to have the handicap/wheelchair ramp for us to continue RVing
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
DSDP_Don
Modern gas coaches will perform well enough to travel anywhere in the U.S. They may not be the first to the top of the hill, but will get there.
As others have noted, check the load carrying capacity and the gross combined weight as that may limit what you can tow.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
chuckftboy
I once owned a 2009 37' class A with the V-10, loved that coach and a friend still owns it. Had plenty of power and had the smoothest running engine I ever owned. The only issue I ever had was the range with the smallish fuel tank. If it had a 150 gallon tank, I might still own it and I think the V-10 is well suited for a 40 footer just don't expect more than 350 miles between fuel stops.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Tal_IL
We had a 2010 Mirada on the F53 chassis with V10 for 5 years and liked it very much. It was right at 37 ft. The V10 is a high rev engine and it took a while to get used to it winding up past 4,000 rpm when it downshifted on hills. But it’s generally regarded as being pretty much bullet proof. We never had issues and would still be in it if we hadn’t stumbled into a Country Coach diesel. That being said, I would hope that the new platform they abandoned the F53 for would offer some advantages
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
Lwiddis
Heat and noise would steer me away from a 40 foot gasser if you move often.
wa8yxm
Mine is a 38' (37'7") with the Old Chevy 8.1L V-8 (No longer made from what I understand but they may have a replacement out) the FORD-V-10 is still made.
Both have nearly the same HP though the CHevy does a better job at low RPM
Plenty of power.
The only caution is the cargo carrying capacity and towing capacity.
999 pounds and 4,000 pounds respectively.
irishtom29
Ford's heaviest gas motorhome chassis has a GVWR (total weight limit of coach) of 26,000 pounds and a GCWR (total weight limit and coach and what it is towing) of 30,000 pounds. Depending on your needs a 40 footer might put you in a bind with regards to payload and the vehicle you can pull behind it. Not necessarily but possibly, it's something to be aware of.
Now Forest River is building that 40 footer you like on the 24,000 pound chassis and I'd be leery of that. I'd be leery of the 252" wheelbase too; that's pretty short and will result in a long overhang behind the rear wheels; that means wide ass tail swing and possibly poor straight line stability.
way2roll
Navigator II
Navigator II
Bruce Brown wrote:
We had a 35' gasser, it was fine.
As to the V10 vs new V8, from everything I've read I know which one I'd go with. I'm hearing a lot of good reports on the new V8. I'm actually considering one for my next truck.
With the exception if mileage. Mileage on the new v8 even in the truck not pulling is really low. That was a consideration in my new truck. I ended up with the 6.7 turbo diesel and getting about 20-21 not pulling, and 14 pulling the FW. I know I got off on a tangent, but the point is, while the new Godzilla is a great engine with lots of lower end torque and quieter, the mileage will probably be less than the V10.
Bruce_Brown
Moderator
Moderator
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Trackrig
I'm assuming if a gasser, it has the front engine. This will mean more heat right next to you while driving, more noise and for me, it's very hard to get over the engine hump getting in and out of the driver's seat.
With the engine up front I'm not sure where it will put your generator? I like my generator up front if I have to run it at night to keep my DP cool for sleeping.
Bill
rk911
we have a '16 Suncruiser 38Q gasser that actually measures to a bit longer than 39', and nearly 55' and 3800-lbs more weightin tow when our toad is hitched up. the rig is powered by the ford v10. the difference in length (minus the toad' is miniscule. we haven't been in the rockies but have done some respectable climbs in AZ. the rig doesn't climb at 55 nor does it pass most vehicles on the climb but it gets to the top without breaking a sweat.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
