gshantz wrote:
Except for dropping the fronts down 20 lbs to 80 PSI as you point out, I'm nearly at Toyo's specs. (Thanks for the page link.) I'll do that before our next trip over the coming holiday - only 50 miles. :-) Right now I need to save some more pennies before taking it in for a checkup. I like your suggestion of things to have them check up on. It just blows me away as to how changing tires could make all that much difference in the ride.
As I said, I'll be sure to let you know when I get further info.
GS
I dropped my steer tires 10 pounds and my tag axles 20 pounds to get them to the proper manufacture recommended specs and it made a huge difference. Very noticeable and favorable.
I look forward to hearing how your first trip goes with the new pressures.
