BillHoughton's avatar
BillHoughton
Oct 19, 2023
freshwater pump maddening problem
The freshwater pump in our RV (2007 Itasca Navion) stopped holding pressure - it would run up to pressure, stop, then cycle every 15-20 seconds (estimated; never timed on the old pump). Based on advice here and at Winnebago, I bought a new pump and installed it; the problem recurred.
A very helpful customer service guy at Winnebago told me how to pressure test the system and stated that, if the system held pressure, the pump was defective. It held 90 pounds of air pressure for four minutes, so I ordered a second pump on the assumption that the first one was defective.
Same (bad word) problem with the newest pump, even after I ran all the fixtures to get the air out of the lines. Checked all kinds of stuff: opened water heater pressure relief valve in case there was air trapped (no), tested the check valve on the inlet to the water tank; removed the kitchen sink faucet aerator to confirm that I was getting water with no air in it; and so on.
A tech at Pentair/Shurflo, the pump manufacturer, suggests that I fiddle with the check valve setting, which I'll do tomorrow.
Another tech at Winnebago told the tech I've been working with that the check valve in the water heater could be seeping internally and creating the problem, although I don't see how that would make a difference (in a closed, pressurized system, pressure is equal everywhere). I can replace it without taking out the water heater, but I'd have to drain the water tanks (fresh water, water heater) and blow out the lines to avoid dripping on electronic parts (smart move, Winnebago!); but, again, I can't understand how it would make a difference.
Any other thoughts?
