dpscll's avatar
dpscll
Furnace problems
My coach has 3 zones but only two (front and back) for furnace. We are currently traveling in cold weather and the rear zone works great but the front is not blowing anything at all and doesnt come on automatically when the temp on the thermostat is set. Is this a fuse problem, or is something else going on?
  • The furnace is a hydro-flame on a 45' sportscoach. Manual suggests checking breaker in furnace compartment which I did and all seems ok, but the one side still wont come on. Tommorrow will be in warmer climate so I guess I will wait to get it checked out there.
  • It would also be useful if you would put coach details in the post or signature.
    And yes we need to kow what kind of furnace, heat pump or ??? you are dealing with.
  • We're probably going to need info on your coach (make, year model) and the mfg of the furnace for a complete answer. When you set the thermostat, do you hear a click when it hits the setpoint?
