Apr-27-2017 04:03 PM
Apr-29-2017 02:56 PM
Apr-29-2017 06:18 AM
Bud
USAF Retired
Pace Arrow
Apr-28-2017 08:14 PM
enblethen wrote:No Bud, that is the correct model number. I had a difficult time also finding a service manual for it on line.
I tried to look up your model and didn't find it. Any other numbers before the "5"?
Apr-28-2017 06:13 PM
Apr-28-2017 03:57 PM
Bud
USAF Retired
Pace Arrow
Apr-28-2017 02:58 PM
Gjac wrote:The fuel pump allows air in each way so I would not assume it would stop the gas from flowing back to the tank.enblethen wrote:I don't know how that works, if I use it every few days it starts right up on the first try after it sits several weeks it always take 3 crank cycles to get it started. I have a spare fuel pump so I can check that tomorrow.
I would think the fuel pump on your genset would block fuel from draining back to the tank.
Apr-28-2017 11:04 AM
wa8yxm wrote:I don't have an Onan I have a Kohlar 5kCM21. There is no prime function.
Check valve won't help.. I can explain why but.. Well, take my word for it wont' help
Two suggestions: First RTFM.. THe manual for my ONAN says to press and hold the STOP button till the light comes on solid... Now if you do this inside you won't notice anything but the light.. But if you do it outside you will hear the fuel pump clicking when the light is on.. Hold it a few seconds longer.
Then press START
I find this helps. but still. Try this
Press Start.. Let it turn over just once or twice (Cranking not running) NOw release,, count to 10 and press again (longer if you don't do the stop bit first)
Mine genrally fires on the 2nd press...... IF it's been a full month, may take a 3rd press.
Apr-28-2017 10:55 AM
Apr-28-2017 10:43 AM
JaxDad wrote:
What generator do you have?
Every Oman has a primer, I case every Generac does, but all the ones I've seen have it.
Apr-28-2017 05:43 AM
Apr-28-2017 05:18 AM
enblethen wrote:Can't find one one my 5KCM21.
If I remember correctly, some Kohlars have a fuel cutoff switch near the carb.
Apr-28-2017 04:09 AM
Gjac wrote:waxerk5 wrote:Mine does not have a prime, but you have a good point about gas sitting in the carb.
Before you start the generator, do you have the option to hold down the shut off button and it will prime the fuel pump? Most Onan's have this function, check to see if yours does.
Also, you don't want a bunch of fuel to be in the carb while it just sits not being used. That will cause the carb to gum up and you'll have running problems.
Apr-28-2017 04:08 AM
Apr-27-2017 08:02 PM
Bud
USAF Retired
Pace Arrow
