We have a 2003 Escapade 31A. Generator cranks off the "Coach" (aka "House") Battery, left side of the body behind the rear tire. It'll do that whether the Coach Battery Switch (control in the entry step well, actual relay inboard of the Coach Battery) is On or Off.
Our Escapade has an Auto Transfer Switch (ATS) that automatically applies generator power to the coach, after about 30 seconds of generator operation. I don't know if that ATS was standard or a option. Which Escapade Model do you have? Some may have an outlet, powered by the generator, that you must plug your shore tie cable into, to get generator power to the coach. ATS does that automatically.
The 12-Volt-DC lights and appliances, unlike the generator, don't operate unless that Battery Switch is ON.
And, if you have an ONAN 4KY GenSet, there's a breaker on the side of the panel containing the generator-mounted controls (that are under the access panel on the GenSet). It has to have its handle pulled outward to close the circuit.
Let us know which model Escapade and which model ONAN you have. Include the one-letter "Spec." You need a good Coach Battery, fully charged, to start the GenSet.
