tatest wrote:
Those are weight ratings, not actual weights.
GVWR is maximum permitted weight for the vehicle, whatever is installed or loaded into it.
GCWR is maximum permitted weight for the vehicle plus anything it is towing.
To find out the actual weight of any vehicle, you have to weigh it.
GCWR - GVWR = 6000 pounds, so if fully loaded you could theoretically tow that much. It is certainly enough for a light towed vehicle, providing you pay attention to Ford's limit of 1500 pounds for tows that do not have their own braking.
The RV manufacturer may have put a lower "maximum tow rating" on the RV, and has likely also put a maximum vertical load limit (sometimes called tongue weight) on the hitch as installed. These could be lower than the rating of the hitch itself, because the hitch is likely installed on an extension to the E-350 frame.
The above information is close to correct, but actually can be many pounds off.
The GCVWR is what the engine can pull.
The GVWR is what should be on the tires, and no more.
If you just take the GCVWR - GVWR and get 6,000 pounds, it is not the right weights. Unless your motorhome is already loaded all the way to it's GVWR, you can tow more than 6,000 pounds.
So take the RV to a scale. Find out the front and rear actual weights. You mentioned the front axle rating and rear axle ratings. you can not exceed those, or the tires likely will be overloaded. Also if you have a really long rear overhand, and tow something like a cargo trailer with a 800 pound hitch weight, it will take off weight from the steering axle, and put it on the rear axle. The ratio is easy to explain. But when you can tell us how much you plan to tow, and what the axle weight are, we can get into the specifics on that.
Basically if you plan on towing less than 7,000 pounds, and have less than 400 pounds of hitch weight, you should be fine.
By checking your axle weights and comparing them to the GAWR, you will know if you are overloading the tires.
Say the rear axle weight is 7,000 pounds and the GAWR is 8,200. By putting a 400 pound hitch weight 8' behind the rear axle, and you have a 16' long wheelbase, you will take away 200 pounds from the front axle and place 600 pounds on the rear axle.
It is very easy to overload the rear axle, especially with a cargo trailer. But a boat is likely less than 200# hitch weight, and should be no problem.
Good luck,
Fred.
