AikenRacer2's avatar
AikenRacer2
HAZY windows in South Caroline
I need to have numerous windows repaired in our 2012 Thor mh. Insulated windows have hazed up. I know about Suncoast in Florida but wanted to see if there is a good repair shop closer to home. I live in Aiken, South Carolina between Augusta, GA and Columbia, SC. Any suggestions?
Thanks!!
  • PsnRebel wrote:
    My coach is doing the same (coincidentally right down the hwy from AikenRacer2). Where do i go on the internet to get a diy repair kit?
    I bought the seal and sealant from DK Hardware. I have no affiliation with them, however I can say I was pleased with them and will use them again if ever needed.
  • My coach is doing the same (coincidentally right down the hwy from AikenRacer2). Where do i go on the internet to get a diy repair kit?
  • Grldst is correct. I did ours this past Spring, it's not a hard job, just time consuming.
    If you decide to tackle it feel free to reach out for any pointers.
  • Suncoast appears to be the closest to you - the other option would be twice as far away, in Searcy, Arkansas.
  • If you’re a DIYer there are repair kits on the internet that I have had good success with. It’s not a difficult job. Also most glass repair shops can repair/replace the glass however they may want you to remove it and bring it to there shop.
