plambrinos
Aug 24, 2018Explorer
Heater wont stop running is the controller faulty?
I purchased a 2000 Fleetwood discovery and just recently the heater went on without cause. I have done some research and the controller 00-00591-200 intellitec was chattering and then stopped chattering. I pulled the fuse and after a short time I re installed the fuse and the heater worked properly for a couple of days then the heater started again without notice. Has anyone had this issue and if so what was the outcome, did replacing the controller fix the problem.
Thanks
Thanks
