GHOST1750's avatar
GHOST1750
Heating problem
Just returned from three weeks in the Tradewinds. Everything went well until the last four days out. All at once the warning buzzer would go off on the slightest grade. It was fine on the straight away but as soon as I started up a slight grade it would start heating up. I nursed it back across the Grapevine in Ca., stopping several times to let it cool down. Taking it to the CAT people Wednesday morning. They seem to think the radiator is plugged and they may be right. May need to take a second out on the rig to pay the repairs. :B
Always something.
  • If you are talking about the air flow being plugged, then they will absolutely have to pull and clean the CAC as well-- that is where the vast majority of the dirt will be (front of CAC).
  • Have Tradewinds in the CAT shop now, Radiator is plugged. They want to remove it and have it cleaned. Waiting for estimate for the service. Also having Thermostats' replaced at the same time.
  • Actually the "oil from slobber tube" being pulled into the cooling package was universal to all diesels with open crankcase ventilation.
    But, let's address the OP's issue.
    VERY easy to check for blockage (BTW, the air flow blockage would not be in front of the radiator, but in front of the CAC (Charge Air Cooler) which is the first thing in the air flow.
    Access the top of the engine (bedroom or closet). You will need to be able to look inside the fan shroud/between fan blades. With a strong flashlight, look in the center. It will be clean (the blades "sling" the dirt to the perimeter). Now, look at the perimeter- particularly the lower perimeter and make sure the fins are equally clean.
    If not, Simple Green EXTREME (formulated to degrease aluminum airplanes so will not harm the aluminum CAC)and a garden hose/garden nozzle should clean it up unless it is really plugged. THIS NEEDS TO BE DONE ANNUALLY ON A REAR RADIATOR COACH!!!!!
    If that is not the problem, then absolutely the first "repair" is to replace the thermostat(s). They are a wearing item. Some Cat 3126/C7's have two thermostats-- in the same housing. Be sure to get the correct gasket. Taking your engine serial number to any Caterpillar dealer should get you the proper parts.
    Other thing to check is the water pump belt. It is NOT on an automatic tensioner, but is a small V belt that drives only the water pump. Check it from under the coach-- driver's side of engine. Front of engine (toward back of coach). It has a manually adjusted idler pulley.
    Let us know what you find.
  • Sounds like oil got into radiator from slobber tube..Known issue with CAT...clean radiator and it should be much better..Also extend the slobber tube down more towards the ground.
