GlennLever's avatar
GlennLever
Help American Dream Water Problems
We left for out trip to Florida.
We have been plagued with problems.
The cruise control that worked intermittently that it went to the shop to be fixed does not work at all now
I figured that I could get by without it, but now we have water problems
when the pump is turned on water comes out of the city water supply connection
the bypass valve is is closed.
I filled the tank before I left.
Is there a check valve at the city water connection to keep the water from coming out???
It is dark and cold and windy here now, I will check in the morning, but I am giving serious taught to aborting this trip, returning to Rochester to have the shop fix the cruise and water problems.
  • It was the check valve. I was able to reset it into place with a small screw driver. We have aboted the trip as there were a number of other small problem, the biggest being the cruise was not fixed. We will make the trip early next year when all the "little" stuff is fixed
    Thanks for the input
  • What everyone has said, check valve failed.
    Also, I had a 98 Dutchstar with intermittent cruise problems. As a temporary thing, I found that running in the "economy mode", the cruise would work just fine. Might be worth a try.
    Bill
  • Bobbo wrote:
    I had that check valve fail on a 2 week trip. For the remainder of the trip, I used a plug from the hardware store to screw into the inlet to seal it. When I got home I bought a new check valve and installed it. Didn't let it ruin my trip.
    just buy a fitting to take an air compressor available at walmart for $2.34 and kill two birds with one piece of plastic.
    bumpy
  • I had that check valve fail on a 2 week trip. For the remainder of the trip, I used a plug from the hardware store to screw into the inlet to seal it. When I got home I bought a new check valve and installed it. Didn't let it ruin my trip.
  • Pickup a 3/4" PVC plug and screw it into the city water connection
    The internal check valve inside the city water connection has failed....cheap plastic junk....just a plunger, sprig and o-ring. The o-ring gets out of position and the plunger doesn't seal.
    Some have luck replacing the o-ring or getting it back in position but they are not worth the effort.
    Plug it off.........use pump. Remove plug and use city water connection when you have it. Simple.
  • There is a check valve at the hose connection for your water cupply. Sometimes they stick. Try poking you finger or something in it to see if it will loosen up. Could also screw a plug or water spray nozzel on to stop the leaking rather than stop your trip.
