Tinstar's avatar
Tinstar
Help me find a fuse
I posted last week about my steps not working any longer. I found it was the controller. I bought a new controller, gear box and motor kit from PPL motorhomes. I installed it today and all is well, except the step lock-out switch. I am not getting any power to that switch and I should have 12 volts with the switch ON (zero volts with the switch OFF). I ran a 12 volt jumper to it and the step lock out works fine with that jumper so I know it's the wire somewhere.
One other thing I found and may be related, is I have no lights in my bays. All of them are out. I am guessing there is a fuse that controls the power to the steps and the bay lights. I CAN'T FIND IT.
1994 Allegro Bus D/P. I've checked all fuses under the fridge (about 6 or 8 fuses), in the dash (10 or more), inside the genset compartment (4 up there) and in the bay with my converter (4 in there). I checked them with a meter and those fuses are good.
Now where else do they hide fuses? I wish they would tell you where all fuses are located.
