Help With Jeep Toad
Don_Parrish
Put the toad, 08 Jeep unlimited 3.6 V6, in the garage and left for five days. Returned, no start, new battery, panel cluster lights dim and bright and dim, "no fuse" appears where odometer displays, no engine crank. Every fuse and relay checked and good.
Any ideas?
Please do not ask if this has anything to do with RV's or camping. It does not, but the collective knowledge of this group can not be overlooked. Lots of you have jeeps.
Thanks for any help.
Don Parrish
7 REPLIES 7
Roadglider09
It's the IOD (Ignition Off Draw) fuse. When bad or not seated correctly it will give you a "No Fuse" error on the dash. This is the fuse that dealers pull so cars sitting on the lot don't drain the battery.
For more info Google "No Fuse Jeep Message". Tons of info.
Michael & Donna
Little Ones Becky & Karen
Deland, FL
2012 Georgetown 350TS
2013 Wrangler Unlimited Toad
Couple of Harleys (when not pulling the Jeep!)
Community Alumni
Not applicable
The very first thing I would check is the ground wires from the battery to where it connects to the firewall or where ever on the new Jeeps.
On my 1999 an older model so there may be no connection but when I first got in to my Jeep on the dealers lot there was no odometer display and I do not remember if it said anything, anyway the service guy said that they still had not put in the fuse yet????? :h So this is a big stretch but it may have something to do with that whatever that is. As posted earlier the Jeep site guys will know.
This is where I go
Jeep technical forum
JimR
Grindstone
Jump it... If it still doesn't crank, it's the starter motor or the starter motor ground cable.
Davehrn
Keep is simple... jump it... if it starts.... its a bad battery
~dave
2010 Coachmen Mirada 32ds
DW: Nora
DD: Silas White German Shepherd / Husky Mix
Rockrash
WWW.nc4x4.com
Go there and ask. Good group of jeep guys. I would try to jump start it before you try too much though. Maybe low amps?
Don_Parrish
Batter reads 12.6 at the cables, not just at the posts. So the system is getting voltage.
John_Wayne
Could be the new batt. needs to be charged. Could have been setting on shelf for a while.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
