timmac
Sep 16, 2018Explorer
Dutch_12078 wrote:
The centrifugal blades in the disposal act as a centrifugal pump impeller as they force the waste against the grinder plate. Did you miss the part where he held the hose up 7 feet high and it still pumped? This is not a new discovery, and according to various posts, quite a few folks have done the same thing with good results. It may seem crazy to you, but does in fact work quite well as others have posted. Try a Google search:
Waste disposal as an RV macerator
Using converted disposal at home would be as easy as sticking the hose through a window into a toilet if there's no sewer clean out available. Just as you could with a costly RV macerator. If you compare the parts in a waste disposal and a macerator pump, you'll see they're actually pretty similar. And if a ~$100 price difference is a "very few dollars" to you, that's great, but some of us have better uses for our money than overpaying for things we can easily make or modify ourselves.
X2
In one of his post to me he said how he has changed out 4 garbage disposals in his lifetime, heck I was a maintenance man for many years I have changed maybe 50 in my life time and they do pump water.
:E
38,721 PostsLatest Activity: May 19, 2025
