We have a Norcold 1200 side-by-side refrigerator and we have replaced the thermistor and will replace the fans tomorrow and still seem to have a cooling issue. Any ideas on what to do/check next?
Thanks for all of the great input, I did change out the thermistor and it is cooling down to 32 (set at 9) in the refer and -7 in the freezer on both AC and LPG. As the day gets warmer (we are in AZ, ouch!) the temp creeps up to 50 in the refer, freezer stays good. The fans do not appear to be working, so that is the next item to replace, I will let you know if that works and thanks again!
