RoadHogg
Dec 11, 2015Explorer
House Battery Charging/MagneTek Model 6332 Power Converter
When we picked up our 1997 GWV Class B in early October, we drove home over the next week or so and although the camper is in near perfect condition, we noticed that the house battery doesn't seem to charge properly...or maybe just doesn't hold a charge. During our trip home it seemed that the house battery would easily go dead as we travelled and would then charge up at night when we plugged into shore power. (I really would like to add a second house battery...having too much battery power can't be a bad thing)
Recently I changed out the chassis battery, the PO had installed a n Interstate HD24-DP deep cycle 505 MCA battery under the hood and IMO, that's an incorrect application for that battery. The engine always started well but we do intend to drive this van all winter and we need a very strong battery in order to handle cold starts without issue.
During my chassis battery change over, I decided to do some testing of the house battery and related charging system. I found that the isolator device under the hood seems to be operating properly. The isolator does not connect the chassis and house batteries together until the engine's alternator is charging. I confirmed that the isolator disconnects the house battery from the engine battery when the engine is stopped and then connects the two when the engine is started...thus allowing the charging of the house battery.
I took the house battery out and gave it a full charge with a good quality automatic charger then I gave it a load test. This battery is an Interstate SRM-27 deep cycle battery rated at 750 MCA. My load test showed that the battery is down a little on CA but not too bad...about 500 Amps.
So, this is all fine, I will replace that house battery some time but there is some life left in it...for the way we camp...usually plugged into at least a 15A supply overnight.
My concern at this point is, the house charger. I didn't test the charger, I'm not sure how in fact. I'd like to be confident that the house charger is both charging up to full potential and that it stops charging when the battery is full.
The house charger is a MagneTek 32 Amp "Power Converter" Series 6300 A Model Number 6332.
Any tips on how to best test the power converter charging system?
