Gjac
Sep 12, 2014Explorer III
How close is too close
Someone posted awhile back about brake lines being too close to the exhaust manifolds causing the fluid too boil on long grades and loss of brakes so I went under mine and looked and found mine were about 1 1/2 ins away from my headers. I also noticed that two lines from the trans to the cooler were only 1/2 in away from the header. I wrapped the brake line with FG cloth because it was easy to do. The trans line would be much more difficult. So my question to those that have added headers to a 454 TBI(Thorley) have you run into this issue and have rerouted the trans lines or is 1/2 in clearance enough not to heat up the lines?
