coolmom42's avatar
coolmom42
Oct 31, 2020
How cold is too cold?
With a water tank above the floor/under the bed, and adjacent water pump, what is the most vulnerable freeze point? (Assuming waste tanks are empty or nearly so.)
Our forecast for Sunday and Monday is 55/30 & 53/33 F, sunny.
I'm inclined to put some heat on in the RV, and open drawers and doors so the plumbing can get some warm air circulated to it. That was adequate for a trailer with exposed water tank, under the same conditions, so it should be adequate for the motorhome. Any reason it wouldn't be?
The furnace is basic unducted. I'm assuming no heated air is directed under the bed, towards the water tank and pump. Is that correct?
