IAMICHABOD
Sep 19, 2016Explorer II
Some of the newer ones come with a black tank flush,a really nice thing to have.
I installed a Quickie Flush in my Class C and it was one of the best Mods I have done, and pretty simple.
I picked the Quickie Flush over the Tornado because of the high failure rate of the swivel part. A few of my friends had them fail and it leaves it useless in the tank.
The only thing that I changed is where the hose connects up with the flusher I put a 90 Degree Elbow in it to reduce the strain on the hose and make it closer to the tank.
![](http://i.imgur.com/ua7SyECl.jpg)
It looks like this when finished, with a quick disconnect on the end.
![](http://i.imgur.com/kewYuwdl.jpg)
Don't get discouraged if it leaks at the hose connections at first they are sometimes hard to get tight. Tightened mine up and have had no leaks anywhere.
Another suggestion is to make a test hole in a piece of wood or something and test fit the device to the hole. I found that the hole size suggested was much larger than needed.
Good Luck.
Good Luck.
38,707 PostsLatest Activity: Feb 18, 2025
