wa8yxm
Sep 29, 2015Explorer III
mowermech wrote:
In many states, 13' 6" is the maximum allowable height of any vehicle.
It is a pretty safe bet that your coach is 13' 6" or less.
Edit: Delete Many (In the phrase Many States) Replaced with ALL.
But that is correct
I like the idea of parking in a facility with a known height ceiling, Or parking under a tree limb or other overhang... Then measure the height to the bottom of the overhang (May be done after moving) and measure the clearance.
Option two. Take a laser level and a wall or other item (Post) at least 14 feet high. Pull out 14 feet of tape (or pull out 10 feet, maker a mark and pull out another four) and mount the thing to the wall/post (Tape works)
Using a laser level on top of the RV.. "Shoot" the tape.. Where the red dot strikes.. that's your height.
Option 3: NOT recommended.. When you drive under the 12 foot high bridge.. And your rig used to be 12'6" high.
38,705 PostsLatest Activity: Jan 27, 2025
