precioustime's avatar
precioustime
Sep 03, 2013
How good are Coachman Forest River rv's?
Quality? Talking about 2014 models. have they been around long, construction quality, ease of operation? Thinking of the 24G Prism with the slideout in the rear with a walk around bed. Appreciate any advise.
  • littlemo wrote:
    I must disagree about Forest Rivers lack of Quality build. They are really up and coming and for the last several years are building quality Motor homes. They have the One-Piece Molded Fiberglass Front End Cap, 2" laminated Gel Coat sidewalls, vacuum bonded with aluminum frame structure, steel backers & block foam insulation.
    Forest River has not been building the Coachman so it does not have the same quality, but they will probably improve this as time goes by.
    That is very good to read.
    I need to clarify that I never looked and a FR up front. I only read of horror stories in 2008/2009 from new FR owners with brand new units having sun light beaming inside hanging cabinetry where the ceiling met the walls. Dealers addressed the split seamwork with pounds of caulk. That being the heaviest of poor design and workmanship.
  • past-MIdirector wrote:
    Coachman as is most Forest River RV's are on the low end of quality. The best people to ask are at collision shop that have specialists in RVs to get the full truth. I've seen a lot of these makes in shops for repair and not very impressed with construction.
    If I understand correctly, Forest River has bought the Coachman out. They have not been making the Coachmen and I must disagree about Forest Rivers lack of Quality build. They are really up and coming and for the last several years are building quality Motor homes. They have the One-Piece Molded Fiberglass Front End Cap, 2" laminated Gel Coat sidewalls, vacuum bonded with aluminum frame structure, steel backers & block foam insulation.
  • The Coachman line in general is marketed as an entry level motor home, built for affordability. They are not known to hold up as well as more expensive motor homes. But if they are inspected often for seal/caulk failures, and are well covered/protected off season, they can serve you well for many years.
    Read this to understand better.
    When shopping for any conventional class-C, the most important consideration is how it is constructed. What methods are built to last, and what methods are built to be most affordable.
    Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
    When shopping for a motor home, don't get distracted with what I call "Eye Candy" and/or "Square Footage". You want to pay close attention to how the house is constructed. Water penetration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets in, it is like termites. By the time you realize there is a problem, a lot of damage has already occurred. Mold can also form and then you have a health hazard. My advise focuses on identifying a Reliably Well Sealed motor home.
    #1 BEST (Very Expensive, Can Be 1.75 to 2 times the cost of Second Best)
    NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, door, roof-top vents and a/c unit, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes are limited in size.
    #2 SECOND BEST
    Common, Affordable, & comes in Many Sizes so this is my main focus
    I own an example of this type. My Rig Here manufactured by Phoenix USA.
    Made in sections, but assembled in a way that greatly reduces the threat of water. Here are the good things you want to look for.
    a) Structural Seams Away From Corners
    When a motor home is driven, the house bounces, resonates, shakes, and leans, many thousands of times. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lower stressed areas.
    b) A Seamless Over-The-Van Front Cap
    A huge bed above the van’s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven. It is common for seams to split there, most troublesome with age & exposure to the elements. The small front aerodynamic cap of a B+ design eliminates the overhang which eliminates most of the resonation, along with most seam work.
    There are a few conventional “C” Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design. Born Free offers a seamless bucket design as seen in This Model. Winnebago's View Here is another fine example. Some manufactures as of late offer a partial bucket design with fewer seams located in less-stressed areas. The Nexus Phantom applies a partial bucket concept. If you plan to accommodate more than 2 people, that extra bed would be extremely important.
    c) A Crowned Roof
    Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after the caulk has dried out from age & sun, as well as fatigue from the change in seasons.
    d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
    A single sheet of fiberglass that rolls over the right & left sides of the roof, down the wall a few inches. The fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
    e) A 5 Sided Rear Wall Cap
    This 5 sided back wall moves the seams around to the sides to areas of much less stress.
    Potentially Troublesome Construction
    Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed. Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example. If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
    There are also rare exception like the Lazy Daze which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body. It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
    About The Chassis
    The most popular is the Ford E-Series with the V10 engine. The Sprinter diesel is a popular alternative to the E350 in the smaller sizes. The GM chassis is not popular, but is a very good choice for the right application. Any of those three brands since 1998 are real good, new or used. If you plan to tow a car or heavy trailer, be aware that the Sprinter is the least powered chassis. People who tow with a Sprinter, take it slower.
    If considering a recent “small” class B+/C motor home, here is a comparison between the two main contenders, the Sprinter with the V6 diesel engine and the Ford E350 with the V10 gasoline engine.
    Advantages Of The Sprinter With Diesel Engine
    - Offers a 35% improvement in fuel economy over the Ford-V10, when both are loaded and driven identically.
    - More ergonomic driver compartment with more leg room.
    - Comfort continues with a car-like feel & quiet ride.
    - A grander view out the windshield
    - Made by Mercedes which people are attracted to.
    Advantages Of The Ford E350 with V10 Engine
    - Given identical motor homes both brand and model, the Ford is around $13,000 MSRP cheaper
    - The Ford V10 engine has 50% more horse power and torque
    - The Ford E350 chassis handles 1430 pounds more weight.
    - The E350 is able to tow a heavier load.
    - The E350 rear axle is significantly wider which translates to better stability.
    - In most places traveled, gasoline costs less than diesel fuel
    - The Sprinter diesel has limited mechanical service shops around North America
    - The Sprinter diesel is typically outfitted with a propane generator. Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
    - This Next Point Is Debatable But Still Worth Noting....The V6 Sprinter diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions or you are dangerously low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford V10 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
    You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Via, View and View Profile. Others like Phoenix USA build their model 2350 and 2400 on both the Sprinter and Ford E350. They will even build it on the heaviest duty E450 upon request for a nominal fee. People who request an E450 for a small motor home, tow heavier things like for example, a multi-horse trailer. You can even special order a E350 & E450 4x4.
    There is so much cool stuff offered in recent years, and even more anticipated with the upcoming Ford T-Series chassis. The general public hopes it will become available for the RV industry. It is kind-of like a Sprinter in size and fuel economy, but hopeful to be much more affordable.
    The Chevy GMC 3500/4500 Chassis
    I do not understand why this chassis is not more popular. It offers more interior comfort than the Ford, but not as much as the Sprinter. It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs. They are also a little better on fuel consumption. One thing to keep in-mind, if you are counting inches to store your rig, the Chevy/GMC adds an additional 9" to the front bumper compared to the Ford. I learned that researching rigs that could fit in my 25'-0" deep garage. By default, the Ford gave me 9 more inches to work with. If you examine my motor home in my garage HERE, you will see an extra 9 inches in length might have been detrimental.
    Engine Power Ratings of Ford, Sprinter, & GMC/Chevy
    Ford - 6.8L-V10, 305hp, 420ft
    Srinter Diesel - 3.0L-V6, 188hp, 325ft
    GMC/Chevy - 6.0L-V8, 323hp, 373ft
  • j-d's avatar
    j-d
    It's been pointed out here in other connections, but it seems Coachmen takes full advantage of the Stretch-Availability of the E450 chassis. This can lead to a bigger turning radius than we'd like, but it also:
    Reduces Tail Drag and Tail Wag
    Tracks Better on the Road
    Allows proper Front Axle Loading
    Decrases chance of Rear Axle Overloading
    Look at the Coach from a Side View. The ones where the Rear Axle is AFT of the center of the Body (not counting cabover) seem to bring up less handling and axle loading issues.
    Include Weighing in your coach selection process. Find out where there's a truck stop (CAT Scales has a lookup online) and include their scales in your test drive. Most C's don't overload the front axle. The trick is to have ENOUGH on the front. I hear two minimum numbers. One is 75% of rated capacity. The other is 1/3 of total actual coach weight. Say an E450-based coach scales at 13000#. 75% of its 5000 front GAWR is 3750 and 33% of 13000 is 4333. We've read where some C's had around 3000 on the front, an overloaded rear, and poor handling.
    Longer wheelbase relieves those problems. Based on reading and experience, a "31-foot" Class C ought to have a wheelbase a few inches either side of 220-inches. Coachmen does that.
  • I am biased because I own one. Get whatever floor plan meets your needs at a price point that fits your pocket book. All brands have strengths and weaknesses. the most important thing you can do is buy from a reputable dealer so that should you need service after the sale, you won't have any issues. Like most brands, Coachmen makes several trim models from entry level to higher end. Very happy with the build quality and materials used in my specific Coachmen model.
  • Coachman as is most Forest River RV's are on the low end of quality. The best people to ask are at collision shop that have specialists in RVs to get the full truth. I've seen a lot of these makes in shops for repair and not very impressed with construction.
  • The Coachmen name ahs been around forever. I have to think that if it was linked with poor quality. Forest River would not have kept the line intact when they bought it.
    They are no better, and no worse than most of the others and better than some, depending on which one you choose
