Griff_in_Fairba
Jul 04, 2021Explorer
DRTDEVL wrote:
I found my dash panel lights were no longer working. I rotated the knob back and forth, and the knob feels right and activates the interior light at the right spot, but nothing from the dash. Is there a common failure point I need to look at? I'm hoping rodents didn't munch on the wiring.
There's light is actually two units combined into one physical unit. A variable resistor (also sometimes called a rheostat) for the dash lights and an off/off switch for the interior light. The variable resistor part could be corroded or simply Tango Uniform. Check with an ohm meter or just get a new unit. (Shouldn't be more than $20)
I'm assuming the gauges in the instrument cluster work. If not, then it may be dash wires or connectors.
38,705 PostsLatest Activity: Jan 24, 2025
