โAug-15-2004 01:22 AM
โJun-25-2008 10:04 PM
65CrewCabPW wrote:
I've seen some Robin Hood M/H's for sale. Are they conventional construction? Or metal frame / fiberglass / other?
โJun-24-2008 05:32 PM
tommyj3 wrote:tommyj3 wrote:
I'm in need of some help from you owners of the older Dodge RV's.
My problem is:
I have a 77 Dodge RV with 440 engine. I am unable to shut engine off with key switch. It starts fine and runs fine, but cann't shut it down. I have replaced the ignition switch with new one and still have the same problem. Any Ideas. Just about got all my hair pulled out on this, what little I have left anyhow.
Just an update to the above problem if anyone is interested.
Turned out to be a bad diode in the alternator. Changed the alternator and all is back to normal.
โJun-24-2008 01:34 PM
My problem is:
โJun-24-2008 10:12 AM
65CrewCabPW wrote:
Well, what age is your motorhome? Most anything built after about 71 or 72 has a decent part throttle downshift. It sounds like your kickdown linkage is not properly set.
Of course, you can always just use the shift lever and hold it back to the speed you want and then manually shift.
Oh, and the dipsticks I've seen with a sensor on the end had some lines and holes in it and you had to fill to one of those markings. It has been so long, I no longer recall any of the details.
โJun-24-2008 10:09 AM
โJun-24-2008 06:22 AM
โJun-23-2008 11:31 PM
clockwork oranjaboom wrote:
My '76 w/727 trany has the sensor-type dipstick as well. I can't find an idiot light for it anywhere, but upon close inspection I could make out a 'full' line just above the oval slot at the tip of the dipstick where the sensor is located. Mine also leaks if I park driver's side low.
Hope this helps,
dave
โJun-23-2008 04:22 PM
โJun-23-2008 11:08 AM
Hope this helps,
dave
The seals around the shafts that are operated by the shift and kickdown levers are leaking.
The job isn't real hard, but you do have to pull the valve body to do it. That leak is common on every old Torqueflight, but unless it gets serious, you can mostly ignore it.
โJun-23-2008 08:57 AM
Hope this helps,
dave
โJun-23-2008 08:54 AM
Hope this helps,
dave
โJun-23-2008 07:41 AM
โJun-23-2008 12:54 AM
munkalido wrote:Griff in Fairbanks wrote:
A727 Torqueflite/Loadflite trannys are hard to kill ... I know, I've tried unusual things that'd kill most other automatics. Keep the fluid full and change the filter once in a while and they'll last almost forever. (Kinda like a Dana 70 rear axle ... just about the only way to kill one is to run it dry.)
My tranny dipstick has an electrical sending unit on it and doesn't really show a full/fill line. How do I know if it's working (where would an idiot light be???) or how do I know if I have enough fluid??
Also, is there a way to get my MH to hold the shift? Right now, it can't wait to get into 3rd and often bogs down (lugs) unless I stomp it into the kickdown or manually hold the shifts.
โJun-23-2008 12:11 AM
โJun-19-2008 06:25 PM
tommyj3 wrote:
Thanks very much for the reply 65CrewCabPW. I've owned said RV for 6 years and no wiring has been changed. I just moved it a couple of days ago, and then I couldn't shut it off. I like the idea of a relay being struck closed. I will be checking this out pronto.
Thanks Very Much
Tom
