โAug-15-2004 01:22 AM
โMay-23-2007 05:27 PM
โMay-23-2007 04:41 PM
โMay-23-2007 02:43 PM
Leeann wrote:
Hi, Lummibeader!
We need to know a bit more about your RV to help you, but many times the switches up there control things like the generator, water pump, lights, which gas tank is in use, etc....a photo might help, too.
What actual make is your motorhome? Dodge simply made the chassis. The 318 is the stock motor on many models/brands of RVs on the Dodge chassis.
What color is the generator? If it's green, it's an Onan. If it's tan, it's a Kohler.
โMay-23-2007 02:33 PM
โMay-23-2007 01:43 PM
โMay-23-2007 01:20 PM
โMay-23-2007 12:55 PM
โMay-23-2007 12:43 PM
โMay-23-2007 12:41 PM
โMay-23-2007 12:32 PM
Leeann wrote:
madtiger, I'd recommend the actual Dodge shop manual for your chassis, as that's going to be a lot more accurate than the Haynes or Chilton. They are still available on eBay - a lot.
manual on eBay as an example.
As for your motor, post your VIN # and we can decode it for you. If it's a small block (318 or 360), the distributor will be close to you if you're in the van looking out the front. It'll be at the front of the vehicle if it's a big block (413 or 440).
โMay-23-2007 12:22 PM
โMay-23-2007 11:58 AM
โMay-15-2007 09:38 AM
โMay-15-2007 05:17 AM
โMay-15-2007 04:18 AM
timmac wrote:
Big_John>>> I am looking at Chiltons auto repair manual and it says for 361, 383, 413, 426W, 440 and 426 hemi to remove oil pan and filter assembly than remove oil pump from bottom side of engine...these exact words.....
