โMar-12-2017 01:10 PM
โMar-13-2017 07:02 AM
โMar-12-2017 07:33 PM
โMar-12-2017 05:41 PM
Pirate wrote:
Read sometime/somewhere that these jacks need to be deployed at least an inch or so to keep pressure. Perhaps Doug can comment on this but I have been in the habit of making sure when I use the jacks that I "use" them instead of just touching the ground.
โMar-12-2017 04:31 PM
โMar-12-2017 03:47 PM
โMar-12-2017 03:45 PM
doxiemom11 wrote:
That happened to us when the fluid was slightly low, but not low enough to set off our alarm. Filled (don't overfill) and cycles jacks up and down a couple time with a final fill and no more problem.
โMar-12-2017 03:43 PM
โMar-12-2017 02:54 PM
โMar-12-2017 01:16 PM
Janss wrote:
Right front jack keeps slowly retracting....like 1 inch after 7-10 days. Happened multiple times. Recently we went away for 6 weeks and when we returned this jack and the left rear jack were both no longer touching the ground. (Left rear just raised due to right front of rig lowering.)
I don't see any obvious fluid leak by the solenoids, nor on the jack foot pad nor on the ground. Any ideas what could be causing this?
