gregg00
Oct 03, 2023Explorer
I appreciate the replies. I will try bypassing the fill valve to see if water goes to tank, Also removed drain valve and ran a air hose inside tank to see if air comes out line to pump- yes. not sure where the sensor pads get the reading, not the seeing the tank sensors like I can on gray and black tanks. Could a blocked vent cause an issue? the fresh water tank is not exposed to find sensors or even find the vent.
38,705 PostsLatest Activity: Jan 14, 2025
