I don't know what it is called.
thriftydutch
I use this silver reflective bubble stuff on my windows to keep the sun out in the summer and the cold out in the winter.I have to replace the front carpet. Can I use this bubble stuff under my carpet to keep the heat out from the engine.
1990 L.E.R. Dodge B 250 Class B 17'
7 REPLIES 7
mlts22
On a friend's "C", a custom Dynamat on the floorboards and doghouse made a large difference, especially if one had bare feet.
Reflectix is useful almost anywhere that it doesn't get so hot that the plastic melts. I use it for the windows on my current rig. I've been thinking that it will be useful both as a layer on top of a windshield as well as a layer inside.
sljkansas
I used the Reflectix on the dog house on my old class C. It kept the floor around the g
Dog house cool enough my foot wasn't burning up.
I also have it on the front bedrooms windows on the fifth wheel to keep it cooler during the triple digit temps here in Kansas in the summer.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
mkguitar
Dynamat is another kind of product- what Dynamat does is convert sound vibration movements into heat by friction within the material- It is not a closed-cell type material as you might want for thermal insulation.
and it's expensive.
a reflective foil barrier may help ( think space blankets)- and for the cost, I think that this would be a good experiment. especially if the padding or carpet protects the cells from breaking down.
Mike
Davydd
The product they use on fire walls in vehicles is called Dynamat or HushMat, both are an EPDM like rubber with a foil face. It will offer some insulative value as well as sound dampening.
Davydd
2021 Advanced RV 144 WB 2500 Class B
2015 Advanced RV Ocean One Class B
RoyB
Reflectix Model # ST16025
16 in. x 25 ft. Double Reflective Insulation with Staple Tab
Sold at Home DEPOT
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Tiger4x4RV
Reflectix. There may be other brands. Great suff!
You could always try it under the carpet, take it out if it does not work.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
bdpreece
Since you can pop the bubbles by squeezing them probably would not last too long.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
