dakdave
Jul 24, 2014Explorer
remove both brake lines from master cylinder and install plugs in cylinder ports.Barely press pedal down have someone warch for bubbles in cylinder,release pedal just after bubbles.
Repeat this untill pedal is rock hard and right at top,you now have bled master cyliner and can quickly reattach lines making sure cylinder does not go empty.
Then bleed brakes as usual
38,705 PostsLatest Activity: Jan 14, 2025
