- DachristianmanExplorerI don't remember and my RV is in storage. I do remember that I had to use my test light to figure out which wire was which on the brake switch.
Finding a good power source that switched off with the key was also difficult. I found one, but it was only fused at 5 amps and my brake controller would blow that one. It took me some searching to find another.
Tom - cj7365Explorer
Dachristianman wrote:
I ran a brake controller for my dolly on my Brave. Getting the wires from the back to the front was quite a small chore. I finally got it wired and it's in full service now. Good luck.
Tom
Yeah I see, just pulled up the wiring diagram, and no connector, so I bought 100 ft roll of 16 gauge wire, wire loom and zip ties.
You wouldn't happen to remember what color wire you spliced into on the brake switch would you? - DachristianmanExplorerI ran a brake controller for my dolly on my Brave. Getting the wires from the back to the front was quite a small chore. I finally got it wired and it's in full service now. Good luck.
Tom - Quick answer No!
Follow the link to get to the Winne wiring diagrams for your Brave.
http://www.winnebagoind.com/diagram/Wiring.htm
About Motorhome Group
38,707 PostsLatest Activity: Feb 18, 2025
