kenbert's avatar
kenbert
Intermittent Turbo
Took a trip to PA this weekend, 4 hour drive. After 2.5 hrs when climbing , the turbo boost started to kick out. With the pedal to the floor the boost would go to 12, down to 5 then up to 12 then down to 5. Kept doing this through entire climb, was normal on level grade.
Pulled into rest area for a while and finished trip with no problems.
Coming home after 4 hrs driving, started the same problem. This time even did it on level grade. Boost would not come on till shifted into 3rd gear, and did the same thing. Boost would not hold, kept falling off.
I am hoping someone here has had a similar problem and give some tips on what to look for. Thanks in advance.
