themoons's avatar
themoons
Inverter and Solar Basics
My newish motorhome has an inverter and solar panels. I'm not exactly sure how they work. My understanding is that the solar panels automatically charge the batteries (Do I need to turn them on?) and the inverter makes it so I can run some of the outlets off of the power from the coach's engine. I'll be diving into the encyclopedia-like manuals this weekend to try to figure it out, but thought I'd ask here for a quick "dummies" guide to get me started.
Thanks in advance!
  • the solar panels should be connected to a controller, that is connected to the house batteries under the step
    with out knowing the panel wattage and the battery type and amphrs
    we can only give the most general advice
    the inverter should be connected to the 'house' batteries NOT the engine battery
    the engine has nothing to do with the inverter or solar, it will in 'most' cases
    charge the engine battery first and house batteries second, while the engine is running
    i do not see a signature in your post
    you might have put some info in your 'profile', i have not looked at that
  • Thanks for the tips. I thought I had included my info in my signature. I guess not. Hopefully this works now. I bought it used, so I don't really know how many watts of solar I have. There are two panels and two batteries under the steps, I believe.
  • Put the make , model and YEAR of RV
    In your profile
    Or signature of your posts
    If your solar is correctly installed
    The output of the controller goes directly to the batteries
    And is always connected, unless you physically disconnect it
    You need to identify how much/many watts of solar power you have
    And how large a battery bank you have
    All this will be a big help to our understanding your system and helping you
  • Be aware that unless you have a large array of solar panels that you will have somewhat limited power from those panels and only when in direct sunlight. Depending on the size of your inverter, the inverter is capable of drawing large amounts of power out of your batteries quickly. You need to learn about power generation, usage and management in RVs. I'd recommend studying something like:
    http://www.marxrv.com/12volt/12volt.htm
    Art
  • You do not need to turn the solar panels on. They have blocking diodes that do that automatically, so that are always connected. Do be aware that if you ever need to disconnect things, for repair or to replace a battery or any other reason, you must disconnect the solar panels before you disconnect the charge controller. Reconnecting, you must connect the charge controller before you connect the solar panels.
    If you put the rig in storage and use a battery disconnect switch to prevent discharge of the batteries, be sure to disconnect the panels before using that battery disconnect switch. Solar charge controllers can be damaged if connected to panels without already being connected to a battery.
  • The solar panels are always connected and typically charge only your coach batteries. For some motorhomes, they also charge your engine battery.
    An inverter gets 12 volt DC power from your coach batteries and supplies 120 volts AC to some of your AC outlets. Your coach batteries will receive a charge while the engine is running.
