Ronaldlee's avatar
Ronaldlee
Inverter/converter
Good morning from a snowy North Carolina. I have a 2006 American Tradition 40Z.I have a problem with my Magnum energy system it is showing a back feed fault on the remote and the generator will run but no power to anything. Has any one else had this problem any help would be appreciated.Thanks Ron
  • Thanks for all the great response when some of the snow clears I will try them.The Mangum Remote is the ME series. Thanks again Ron
  • exactly what "magnum management system" is this?
    We have a magnum 2012 inverter, that error message is not in the book.
    Our Energy management system is by another company though.
  • Have you checked the circuit breakers on the Magnum....two on the side of the inverter.
  • Had a similar problem with our Xantrex Prosine 2.0 pure sinewave inverter.
    I disconnected the AC power AND the battery cables. Waited 10 minutes, reconnected, all was well. Worth a try.
  • Thanks for the reply but there is no power to anything.The management system is showing green lights to everything.Thank you again
  • First, I would contact Magnum Energy. They are known to be very helpful solving problems over the phone.
    The generator will run but no power to anything.
    Start by checking breakers on the generator. Next step would be to check the transfer switch, then on to the breaker box inside your coach.
    The "no power to anything" statement.!
    Do you mean just some of the 120V plugs?? Could be as simple as one of the breakers on the inverter
