Apr-17-2017 06:12 PM
Apr-18-2017 09:06 AM
dougrainer wrote:2chiefsRus wrote:
We also have a 2007 made by the same manufacturer, although it is a 2007 Monaco Knight. You don't specify which Holiday Rambler model you have. Our Knight did NOT charge the batteries from the engine running as it came from the factory. I should add that it did say in the manual that it was set up to charge from the engine. When we contacted Monaco we were told that the manual was a misprint and that function was only available on a "high end" coach.
ALL MONACO'S CHARGE BOTH BATTERY BANKS FROM THE CHASSIS ENGINE. PERIOD. I don't know where and who some of you talked too, but as a Technician that serviced NEW Monaco's until they went under in 2007(from 1999 when we took them on), and STILL service them all, the system does charge BOTH battery banks from the engine Alternator. NOW, there is one exception. IF you have the Genset ON while driving, the COACH battery charge solenoid from the Chassis Alternator is locked out, because the Inverter/CHARGER will be charging the Coach batteries. Turn the Genset OFF while driving and the Alternator comes back online and charges the coach batteries. Now to the last statement about hi end. That refers to the Trickle charger system that charges the CHASSIS batteries while camped. The lo end Monaco's/HR's did not have that Module installed from the factory. Doug
Apr-18-2017 07:34 AM
SCVJeff wrote:
What I'm missing here is the "Inverting" comment.. That has nothing to do with the charge process, and is a user select manual button push.
Apr-18-2017 05:34 AM
Apr-18-2017 05:21 AM
Apr-18-2017 05:08 AM
Apr-18-2017 04:12 AM
Apr-18-2017 01:58 AM
Apr-17-2017 11:50 PM
Apr-17-2017 08:52 PM
prstlk wrote:
We have a 2007 Holiday Rambler DP with an Onan 8500 Generator and an inverter.
The way it is set up through the Magnum Energy panel inside, our batteries do not charge as we are going down the road. The only way to charge them is to start the generator and run it for 2 or 3 hours or plug into shore power.
We called the manufacturer of the panel and they told me that I was to start the coach and go back and look at the panel. If it says “inverting” then it is not charging while the engine is running. This is in fact what it says. He basically told me that some charge while going down the road and some don’t and that it depends on how the MH manufacturer set it up.
Can someone tell me what I would need to do to have the batteries charge while the engine is running and we are moving?
Apr-17-2017 06:39 PM
Apr-17-2017 06:27 PM
