MrWizard
Jun 04, 2016Moderator
thats 50amps charging, and that should work for the time being
just don't leave it plugged in and charging the batteries 24/7 in the storage shed
the older magteks had a reputation for boiling the batteries dry
there are better option but not absolutely necessary you replace it right now
but that is NOT an inverter and will Not supply 120v to power the fridge
it is a 'battery charger' and house DC supply
when ever the generator is running or shore power is plugged in, it charges the batteries and gives you 13.xx volts to power the lights water pump etc..
i sealed the lower vent with alu heat vent duct tape
in my case there is adequate vent space all around the fridge for the heat from the closed in coils to dissipate
i left the top vent in place, i have all my solar wiring coming down behind the fridge, but installed a piece of plywood as a partial baffle/block to limit windy down gusts in to RV, put allow for any heat to rise out that way as secondary fridge ventilation
38,705 PostsLatest Activity: Jan 20, 2025
