drcarr57
Oct 09, 2013Explorer
Inverter
The voltage shown inside the coach useing a plug in meter shows 130+ volts. This does not seem normal.Is there a regulator on the inverter, that may be going bad? The inverter is a Xantex Freedom 458.
tomousecap wrote:X2
First thing you need to do is get a "True RMS" volt meter when measuring inverter outputs. True RMS can be very different then what simple meters think is correct.... :)
