aswagerty14's avatar
aswagerty14
Is a Damon Challenger a decent motorhome?
We are looking to purchase an older motorhome (yes I know the possibility for issues but that is what we want to do and will get an inspection before buying anything) and came across a 2004 Damon Challenger in really good condition for around the same price as the late 90's Rexhall Aerbus we are looking at. It only has 36k miles and the rex has 77k. But it's just barely more expensive. Does that mean that these aren't as reliable or aren't as well built as other brands? What would you personally do as far as making a decision?
  • I have a 2006 Daybreak. That is the model below the Challenger. It has had some problems. Most of which I see on this forum several times. It has gotten me and my family to every place we wanted to go. I'm not sure about the 04 but mine had a recall many years ago to move the hydraulic hose's away from the engine block. Check that they are tied back. I would think if there hasn't been a problem with them by now you would be safe. All my components work great. AC, Fridge, slides, water heater, pump etc.
    As everyone says, get it checked out.
    Good luck.
    Gary
  • My addition says its 17 years old--not 27. I always buy used and ONLY top end units. Currently have my 2nd Monaco DP. Still a entry level thats been taken care of will get the job done
  • You continue to get hung up on brand. And everyone keeps telling you that brand doesn't matter on MH's 16-22 years old. Condition does. The most important question you should be asking yourself is what floorplan you want. Then look for units with that floorplan in your price range and THEN start comparing.
  • Ultra low mileage (just over a thousand a year) isn’t necessarily good for a twenty-seven year old coach or any motor vehicle. Get a good house and chassis inspection and review the maintenance records.
  • Damon was bought out by Thor quite some time ago. As stated above, it was an entry level coach. There's nothing wrong with that, but you should just learn as much about the coach as you can in terms of how it was constructed and what components were used.
    If considering a MH in that age bracket, the more important factors are condition and service records along with determining what price items may need replacement or repair. If everything is original, you have to expect that there will be some expenses. Then you have to decide whether it's still a good purchase or would you be better off buying something newer or that has had more renovations.
    There are no easy answers. You have to learn as much as you can about every aspect of a motorhome, from the chassis, engine/transmission on up to how the "house" is constructed and equipped. And, prior to purchase, getting the rig inspected by a professional is definitely something to consider unless you have a lot of expertise on RVS.
    Good luck in your search!
  • Those were/are entry level motor homes. So not alot of options. And no luxury features. Condition depends on how the previous owner kept it. Oil changes? (Engine and generator, how many hours on generator?). How old are the tires? How are the brakes? Has he trans fluid been changed? Brake fluid? Coolant?
    Any signs of roof leaks? Has the roof been inspected and sealed periodically? Is everything working?
    What’s the asking price?
