Is It A Rear Engine Or Rear Drive That Makes It A Pusher?
PastorCharlie
All vehicles except those that are front wheel drive propel the vehicle from the rear. Front engines with rear wheel drive are pushers.
Why the big effort to segarate vehicle drives by engine choices?
Isn't it just another way to post engine preference? :h :R
23 REPLIES 23
valhalla360
Nomad III
Nomad III
It's just a description of where the engine is mounted. As the wheel base gets longer, there are design advantages to putting the engine in the back closer to the drive axle.
It does often get used as a hint that it's a more expensive unit as your more expensive units tend to be DPs and a lot of your less expensive units tend to be front engine.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rv2go
This reminds me of a old debate as to whether a horse hitched to a plow is Pushing or Pulling the plow. :B
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
RLS7201
Maybe your initials should stand for Politically Correct.
It's a slow day at my house too.....GRIN
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
msmith1199
The term "pusher" just refers to where the engine is located since it is an important feature to many people. I think we all know that the vast majority of motorhomes are powered at the rear wheels whether the engine is in front or back. It doesn't literally mean pushing versus pulling, just front engine or rear engine.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
DrewE
It is more a description of the chassis configuration than the driven wheels. If the engine is in the back, it's a pusher. I may well be wrong, but I think the term comes to RVs from transit bus descriptions (and may well have been influenced by aircraft configurations with pusher vs. tractor propellers).
I suppose it would be possible, though not particularly sensible, to have a front wheel drive pusher chassis.
BB_TX
I think it is just a matter of people wanting to attach catchy names. Diesel pusher somehow sounds a little more exotic than rear engine diesel.
MrWizard
Moderator
Moderator
Except for GMC and Revcon
Almost everything is rear drive, even FRED.. FRONT ENGINE DIESEL
Have rear drive
A pusher AKA DP.. Is engine in the rear
The are even gas pushers that have been built
I can explain it to you.
1997 F53 Bounder 36s
mike_brez
Engine in front pulling,engine in rear pushing
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
K_Charles
With the engine in the back it is usually much quieter.
