RCtime
Nov 21, 2013Explorer
I agree with Sowego, I bet you have some air leaks going on, especially if you have a drivers door.
I had some serious issues with air leaks and solved them by getting a drop cord trouble light and going around under the dash and floorboard area and observing, when the hood is open and underneath where the light shines through. This takes two people. you will be surprised. mark the areas and get expanding foam and seal it., then spray it black
If you have a drivers door you may have to redo the rubber seal or double it up.
Your dash air and heater will not heat or cool your whole coach but should keep you comfy up front if you keep out cold air intrusion if its functioning properly.
38,779 PostsLatest Activity: Jun 18, 2026
