SnomasExplorerMar 29, 2022Is water pressure too high?If I up grade to a new 3 gpm pump vs 2.5 gpm water pump the new pump shuts off at 55 psi vs 45, will my water lines hold up ? I also just installed a new domestic 320 toilet.
bobndotExplorer IIApr 01, 2022Yes, isolate or insulate the lines , first and easiest thing to do .If that doesn't do the trick, research an ‘accumulator tank’ .
Related ContentWater pressure regulator...No water pressureWater pressure issueHigh Anxietyriding nose high
