Frjay's avatar
Frjay
Jayco slide out awning rafters
I have a jayco Sennaca with a 23' slide out. It has a rafter system that folds in and extends when you operate the slide. I have looked every where to locate parts for it and can not seem to find any information. Does anyone know of this system and where it can be found? Thanks for your help. It helps hold the awing up for support. It is a carefree awning
  • When I needed a part for my rafter I contacted Carefree of Colorado directly and they were able to hook me up with what I needed. I happened to be traveling near Boulder Colorado at the time and I just went to the factory where I was able to get what I needed. I had spoke to them on the phone previously and they were going to ship what I needed to me but I knew that I was going to be there in 2 weeks so I just went and picked it up.
  • Start with getting serial number.
    With your awning fully extended, standing under your awning with your back to the coach, there is a tag on the awning tube on the far left hand side or right. Or on awning arm. All info is contained in these numbers, model, style including color. Then go find parts after you know what model you have.
    https://www.e-carefree.com/carefree/SerialLoc.html
    Carefree customer service was good to me, after I had serial number.
  • When in doubt, go with the manufacturer... When the manufacturer doesn't come through try ebay for china parts.
