lj2654
Apr 05, 2017Explorer
On my steps I removed the motor and linkage assembly because when opening the steps the motor kept running for an additional 4-5 seconds. I had watched a couple of videos on You tube and it seemed simple to do. After removing the motor I decided to take it apart. inside was the main gear which had three cushioning plastic clumps, actually only two as one was ground up and about gone. probably my issue I thought. I found a motor on Amazon for $49 that looked the same. Two day shipping and installed it in about 30 minutes and it is perfect again.
38,707 PostsLatest Activity: Jan 05, 2014
