LOG
Jul 31, 2018Explorer
Koni FSD Shocks
Would those members who have installed Koni FSD shocks on their Class C do it again? Or do you regret the decision. Thanks.
pnichols wrote:
As I've stated before in these forums - I have absolute proof that the Koni FSD shocks in the rear of our Class C reduced the cracks/pothole pounding back there when traveling: Both our shower door gravity latch back there now stays latched, and the little plastic shelf on the back wall never has it's contents bounce out.
Of course maybe Bilsteins would have done the same - but nothing in the Bilstein literature states that they provide a damping rate that varies depending upon the quickness (frequency) of road surface change.
I really think that where the high frequency light damping mode of the Koni FSD shocks comes into it's own is on RVs that are really stiff springed relative to the motorhome's weight (which is our situation with a 24 foot Class C on the E450 chassis). In these situations a quick bump in the road does not need any shock's resistance added to the spring's resistance - so light or no shock damping is better for reducing the jolt.
Most RVs on the E350/3500 chassis and larger RVs on the E450/4500 chassis - will have a higher vehicle weight to spring stiffness ratio that is not going to transmit sharp jolts from the roadway into the vehicle nearly as much as a lower ratio will. I'm sure Bilsteins (and many other shock brands) will handle these situations well enough.
LOG wrote:
Both rode like a new Lexus compared to this Class C motorhome.
LOG wrote:
Our coach weight on rear axle is 9360 pounds. The axle weight rating is 9450. According to this discussion, the coach should not be pounding as much as a lighter weighted E450. Our coach pounds a lot and is the reason I am thinking about new shocks. I have never ridden in another e450 motorhome, shorter or longer. I do not believe that the pounding could be more than the pounding in our motorhome.
gmctoyman wrote:
Replaced relatively new yellow shocks with the FSD's, would not hesitate to do it again. Had them on my Foretravel and loved them there also.
IAMICHABOD wrote:OFDPOS wrote:
Nope would not do it again . Yes I regret putting them on.
Listened to the popcorn gallery instead of my gut feeling telling me to stay with the Bilstein's !
I have read all of your posts about the FSD shocks and I would not be interested in them at all,I will stick with my Bilsteins!
I was wondering if This offer is still open,who knows you may have a taker :B :B :B
