DrewE
Oct 13, 2017Explorer II
Farmboy666 wrote:TippleUnduly wrote:
I own the same 260ds coach and like it!
The drain valve is behind a black panel, about 5x9
' inside the largest compartment on the driver side. There are other valves in there, too. One of them has to be opened to add fresh water to the tank. I had to ask Coachmen about how to fill the tank!
Bill
It sounds like you don’t have a gravity fill for fresh water either. I am going to install another pump so I can pull out of a portable water tank to fill rv tank when city water not available.
If you have a winterize suction port, you can do that already with the built-in pump. Just set the valves for winterize and open the fill valve.
38,707 PostsLatest Activity: Jan 05, 2014
