Mr__Coach
Mar 30, 2015Explorer
Leveling jacks not working
OK, so just purchased this 2000 Damon intruder and the hydraulic jacks aren't working. I've done the procedures to make them work but still nothing. I've put it in park, set the parking brake, turn the switch on lights come on but nothing happens. My system is the HWH 225 manual leveling system. I have green lights but jacks do not extend and hear no pump running. Checked voltage at the pump and have voltage going to the pump through the main power supply connection but nothing that goes through the solenoid no power reaching the pump. The 2 wires off of the solenoid are hot as well when the switch is on. I'm not that familiar with these jacks system so I don't know where else to look. I have checked all fuses that I know of and they are all good.. What else should I check? Also my heater fan motor in my dash only runs on high, replaced the relay switch and the resister still works only on high.. Usually that fixes the problem but not on this one anyone have any ideas on that as well?? thanks..
