Explorer1016
May 26, 2015Explorer
Not sure what rig you have but those patio blocks are pretty brittle and more than likely will break in half when you put your RV on them. i park mine on limestone rock all year long but i drive it a lot. My RV rarely sits still for more than any 2 week time period so any type of block would be more work than it is worth.
Parking any type of vehicle on concrete for prolonged periods is one of the more damaging materials for tires due to the chemical reaction between the tire compounds and cement and additives. Over time, a concrete draws the oils out of a tire and if the vehicle remains parked for long periods tires can develop flat spots.
If it were my yard and I was spending the money for a contractor to cut in a level area for parking I would have some 2" minus rock brought in, have the contractor spread it out with whatever machine he used to cut your grade with and park on that. This still requires maintenance due to settling throughout the freeze thaw seasons and then the rainy season but after several years of adding rock and additional grading you should end up with a nice solid rock parking area and driveway. Then later you can pour a concrete pad over it or even lay asphalt on it for a more permanent pad.
38,769 PostsLatest Activity: Mar 31, 2026
